[geos-devel] [GEOS] #699: Optimize Geometry->Intersection with rectangular argument
geos-trac at osgeo.org
Tue Sep 9 09:33:33 PDT 2014
Reporter: strk | Owner: geos-devel@…
Type: enhancement | Status: new
Priority: major | Milestone: 3.4.3
Component: Default | Version: 3.4.2
Severity: Unassigned | Keywords:
Comment(by strk):
I'm currently in the process of slightly modifying the algo so that points
on the rectangle boundary are also included in the output (if the other
geometry has any intersection with them).
This requires reviewing each testcase and adapt it to the new expectance
(the code part wasn't hard)
Ticket URL: <http://trac.osgeo.org/geos/ticket/699#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
