[geos-devel] Fwd: Geometry/Rectangle Intersection: line touching rectangle
Mika Heiskanen mika.heiskanen at fmi.fi
Fri Sep 12 10:04:10 PDT 2014
On 09/12/2014 07:31 PM, Sandro Santilli wrote:
> But distinguishing between which boundary lines will need to be
> added to the result and which not is still not done explicitly.
I believe I can help with that. First I'll have to check your changes
to the algorithm to catch up.
Regards,
Mika Heiskanen / Finnish Meteorological Institute
