[geos-devel] Extent-limited graph building ?
Rémi Cura remi.cura at gmail.com
Fri Sep 19 06:23:05 PDT 2014
Thanks for the information,
this is a very intersting subject in my opinion.
Cheers,
Rémi-C
2014-09-19 15:05 GMT+02:00 Vincent Picavet <vincent.ml at oslandia.com>:
> Hi there,
> Le vendredi 19 septembre 2014 14:46:52, Sandro Santilli a écrit :
> > Another use case: a polygon with 250k holes intersected with another
> > with the same structure. Also in this case it would be better to split
> > the polygon into multiple smaller ones, but it's a bit harder to do,
> > and requires invoking the intersection again (for the split).
> As far as I know, this is the kind of use cases Korotkov & al are trying to
> get fast in PostgreSQL (and PostGIS) with their VODKA indexing concept, a
> kind
> of subindexing.
> Some information here :
> http://www.pgcon.org/2014/schedule/events/696.en.html
> Vincent
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20140919/0650af3d/attachment.html>
