[geos-devel] Extent-limited graph building ?
Sandro Santilli strk at keybit.net
Fri Sep 19 09:32:18 PDT 2014
On Fri, Sep 19, 2014 at 06:17:33PM +0200, Sandro Santilli wrote:
> The testsuite shows no failure with the noding validator off
Forget this, I actually found many:
 tests/xmltester/tests/robustness.xml: case1: test1: areatest(): failed.
 tests/xmltester/tests/ticket/bug392.xml: case1: test2: union(A): failed.
 tests/xmltester/tests/ticket/bug459.xml: case1: test1: union(A, B): failed.
 tests/xmltester/tests/ticket/bug527.xml: case1: test1: union(A): failed.
 tests/xmltester/tests/ticket/bug586.xml: case1: test1: intersection(A, B): failed.
 tests/xmltester/tests/ticket/bug599.xml: case1: test3: union(A, B): failed.
 tests/xmltester/tests/stmlf/stmlf-cases-20061020.xml: case1: test1: areatest(): failed.
 tests/xmltester/tests/stmlf/stmlf-cases-20061020-invalid-output.xml: case1: test1: areatest(): failed.
So it looks like we still need to check output noding (pity!)
--strk;
