[geos-devel] Exposing PrecisionModel, GeometryPrecisionReducer in the C API
Sandro Mani manisandro at gmail.com
Thu Jan 8 04:08:12 PST 2015
On 08.01.2015 12:37, Sandro Santilli wrote:
> On Wed, Jan 07, 2015 at 04:48:24PM +0100, Sandro Mani wrote:
>> So this would mean an API like:
>> /** Create context handle **/
>> extern GEOSContextHandle_t GEOS_DLL initGEOS_r(GEOSMessageHandler
>> notice_function, GEOSMessageHandler error_function);
>> initGEOS_r_fixedPrecision(GEOSMessageHandler notice_function,
>> GEOSMessageHandler error_function, double scale);
> I don't think it's needed to create a context with non-default
> factory, given we have methods to change it later.
>> /** Set context handle precision model **/
>> void GEOSContextHandle_t
>> GEOSContext_setPrecisionDouble(GEOSContextHandle_t* handle);
>> GEOSContext_setPrecisionFixed(GEOSContextHandle_t* handle, double
>> scale);
> Yes.
>> /** Precision reducer **/
>> extern GEOSGeometryPrecisionReducer* GEOSGeometryPrecisionReducer_create();
>> extern GEOSGeometry*
>> GEOSGeometryPrecisionReducer_reduce(GEOSGeometryPrecisionReducer*
>> reducer, GEOSGeometry* geometry);
>> extern void
>> GEOSGeometryPrecisionReducer_destroy(GEOSGeometryPrecisionReducer*
>> reducer);
> Or, just calling GEOSGeom_clone() after setting context precision
> to fixed ?
This would be very compact, though possibly it makes it quite
un-inutitive for users to even realize that the reduce functionality is
implicitly exposed through the C API. Some comments could fix that though.
>> The changes needed for reference counting are somewhat invasive IMO.
> True. And I'm not sure it can be done w/out touching the C++ API
> either.
Unless I'm missing something, it should be doable, by keeping the
reference count in GEOSContextHandleInternal and doing all the couning
in geos_ts_c.cpp.
So to wrap up, things currently look as follows (which I actually think
is quite neat!):
/** GEOSContextHandle_t internally keeps a reference count, set to 1 on
creation
  * - *All* methods producing a GEOSGeom increase the reference count
  * - GEOSGeom_destroy decreses the GeometryFactory reference count, if
0, it destroys the context
  * - finishGEOS_r decreses the reference count, if 0, it destroys the
context
/** GEOSGeom_clone() clones the geometry and applies
PrecisionReducer::reduce
  *  if the PrecisionModel of the current context is different than the
that of
  *  the passed geometry
GEOSContext_setPrecisionFixed(GEOSContextHandle_t* handle, double scale);
