[geos-devel] [GEOS] #753: cannot build geos 3.5.0
GEOS geos-trac at osgeo.org
Mon Nov 2 03:22:31 PST 2015
 Reporter:  rashadkm    |      Owner:  geos-devel@…
     Type:  defect      |     Status:  new
 Priority:  major       |  Milestone:  3.5.1
Component:  Default     |    Version:  3.5.0
 Severity:  Unassigned  |   Keywords:
 trying to make geos 3.5.0 package for osgeo4w.
 include could not find load file: GenerateSourceGroups
 -- Looking for stddef.h - found
 -- Check size of __int64
 -- Check size of __int64 - done
 -- Performing Test HAVE_STD_ISNAN
 -- Performing Test HAVE_STD_ISNAN - Failed
 -- Performing Test HAVE_ISNAN
 -- Performing Test HAVE_ISNAN - Success
 -- Performing Test HAVE_STD_ISFINITE
 -- Performing Test HAVE_STD_ISFINITE - Failed
 -- Performing Test HAVE_FINITE
 -- Performing Test HAVE_FINITE - Success
 -- Generating revision header
 C:/OSGeo4W/usr/src/osgeo4w/geos/geos-3.5.0/geos_svn_revision.h
 Can't fetch local revision (neither .svn nor .git found)
 Not updating existing rev file at GEOS_SVN_REVISION
 CMake Error at CMakeLists.txt:326 (include):
 CMake Error at include/CMakeLists.txt:57 (GenerateSourceGroups):
   Unknown CMake command "GenerateSourceGroups".
 -- Configuring incomplete, errors occurred!
 See also
 "C:/OSGeo4W/usr/src/osgeo4w/geos/geos-3.5.0-build/CMakeFiles/CMakeOutput.log".
 See also
 "C:/OSGeo4W/usr/src/osgeo4w/geos/geos-3.5.0-build/CMakeFiles/CMakeError.log".
 C:\OSGeo4W\usr\src\osgeo4w\geos\geos-3.5.0-build>cmake --build . --config
 Release --target INSTALL
 NMAKE : fatal error U1073: incapable d'obtenir 'INSTALL'
Ticket URL: <https://trac.osgeo.org/geos/ticket/753>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
