[geos-devel] [GEOS] #753: cannot build geos 3.5.0
GEOS geos-trac at osgeo.org
Wed Nov 4 07:45:28 PST 2015
 Reporter:  rashadkm    |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:  3.5.1
Component:  Default     |     Version:  3.5.0
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Comment (by mloskot):
 Replying to [comment:9 rashadkm]:
 > sucessfully built geos 3.5.0 for osgeo4W 32bit
 > 1. geos-3.5.0.tar.gz from
 http://download.osgeo.org/geos/geos-3.5.0.tar.bz2
 > 2.
 https://trac.osgeo.org/geos/browser/trunk/CMakeLists.txt?rev=4112&format=txt
 > 3.
 https://trac.osgeo.org/geos/browser/trunk/cmake/modules/GenerateSourceGroups.cmake?format=txt
 > and  when running cmake, I added -DCMAKE_CXX_FLAGS:STRING="-DNOMINMAX"
 > TODO:
 > backport (2) and (3) to 3.5.0 release
 > include -DNOMINMAX patch inside the (1) if compiler is MSVC.
 > optional. I would also added /EHsc for msvc compiler in the
 cmakelists.txt
 > Do you prefer to create a patch against trunk?
 Great job. That is the testing I was asking for.
 No need for patch, I will merge the related changes from trunk to
 branches/3.5.
Ticket URL: <https://trac.osgeo.org/geos/ticket/753#comment:10>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
