[geos-devel] [GEOS] #725: GEOS allows relate ops on GeometryCollection, while JTS and PostGIS do not
GEOS geos-trac at osgeo.org
Fri Nov 6 14:05:40 PST 2015
 Reporter:  mwtoews     |       Owner:  geos-devel@…
     Type:  task        |      Status:  new
 Priority:  minor       |   Milestone:  GEOS Future
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by strk):
 So looking at history it seems this lack of exception throwing was due to
 a misunderstanding between Paul and Martin. Martin was suggesting to
 remove the check for _UnaryUnion_ while the checks were removed by Paul
 for all predicates instead.
 I suggest to put the checks back in place.
Ticket URL: <https://trac.osgeo.org/geos/ticket/725#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
