[geos-devel] updating geos 3.5.0 source archive.
Jürgen E. Fischer
jef at norbit.de
Tue Nov 10 03:11:39 PST 2015
Hi Mateusz,
On Tue, 10. Nov 2015 at 10:50:57 +0100, Mateusz Loskot wrote:
> > Why not? Other projects have to. I'd prefer to keep the C++ API out
> > of the picture.
> If I may, one correction: other projects do NOT have to, but they choose to.
> GEOS C++ API is an official API perfectly supported and
> recommended to use by GEOS users.
Sure. And as the C-API doesn't cover everything, it's sometimes even
unavoidable to use the C++ API (or requires to extend the C-API).
> There is, however, cost involved. That is, GEOS does not promise C++ API/ABI
> stability, so those who choose GEOS C++ API should be aware they may need
> to update change their code more frequently.
Also right - plus that we need to either pick one C++ compiler that works for
everyone (Qt and reverse dependencies currently use 2010 in OSGeo4W - not
2012), leave some behind or ship a myriad of different packages to suit
everyone.
> So, I don't think it's a good idea to forbid the freedom of GEOS API choice,
> especially if it is a choice between officially supported APIs.
I just stated a preference - and asked whether it is feasible to port OSSIM to
the C-API.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20151110/78b877b8/attachment.sig>
