[geos-devel] [GEOS] #713: [Patch] Add GeometryPrecisionReducer to C API
geos-trac at osgeo.org
Thu Oct 1 04:18:39 PDT 2015
Reporter: smani | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.4.3
Component: Default | Version: 3.4.2
Severity: Unassigned | Resolution:
Keywords: |
Comment (by strk):
GeometryPrecisionReducer can change or not change the geometry factory of
the reduced geometry, depending on how it is constructed. If you pass a
new GeometryFactory to the constructor, it will use it for the output
geometry, otherwise it will not. Your implementation is passing a
PrecisionModel rather than a pointer to a GeometryFactory, that's the
problem.
This brings us to the need of exposing a GeometryFactory, more than a
PrecisionModel.
Ticket URL: <https://trac.osgeo.org/geos/ticket/713#comment:15>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
