[geos-devel] [GEOS] #713: [Patch] Add GeometryPrecisionReducer to C API
geos-trac at osgeo.org
Thu Oct 1 04:23:19 PDT 2015
Reporter: smani | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.4.3
Component: Default | Version: 3.4.2
Severity: Unassigned | Resolution:
Keywords: |
Comment (by smani):
First thing to decide IMO is how to proceed for QGIS 2.10: I can fix my
geos_extra to construct the precision reducer correctly, get the fix
commited, and then as far as QGIS 2.10 is concerned things are ok and then
we can take the time to design a proper C API for GEOS. If this is okay
with you, I'll do that and then yes, we can continue where we left of on
the mailing list.
Ticket URL: <https://trac.osgeo.org/geos/ticket/713#comment:17>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
