[geos-devel] Exposing PrecisionModel, GeometryPrecisionReducer in the C API
Sandro Santilli
strk at keybit.net
Thu Oct 1 07:47:52 PDT 2015
So to followup,
it is confirmed that the QGIS wrapper in its current incarnation
is not useful for the purpose of changing the precision model of the
operations.
Meanwhile I've worked on a reference-counting mechanism for
GeometryFactory that would allow us to expose a single function
to change a geometry's PrecisionModel (effectively it's reference
"GeometryFactory") in a way that avoids memory leaks.
Here's the code: https://github.com/libgeos/libgeos/pull/52
Basically each GeometryFactory will be holding a count of Geometry
objects referencing it. Every Geometry will signal its birth and death
to it. When you don't need a GeometryFactory anymore you can request
its auto-destruction and it'll stay alive only as long as any of its
child is will also be alive.
Explicitly deleting a GeometryFactory before any of its child would
become a coding error, in the current version of the code. Eventually,
this may change to be more tolerant (at the cost of growing the size
of a GeometryFactory to store all child pointers in a list).
With such kind of automatic memory management we'd be in a position
to expose at the C-API level a single function to change a
Geometry's precision. Such function would find or create an appropriate
GeometryFactory, assign it to the geometry and mark it for
auto-destruction. The calling code would have no need to ever know
about the existanc eof such GeometryFactory object.
How would you feel about such a change ?
--strk;
On Wed, Sep 30, 2015 at 06:16:03PM +0200, Sandro Santilli wrote:
> Sandro, I've been looking at the wrapper you added to QGIS
> but from what I read it doesn't seem that the geometry coming out
> of GEOSGeometryPrecisionReducer_reduce has an updated PrecisionModel,
> which means overlay operations won't be using that new model.
> Do you confirm ?
> If that's the case, the wrapper doesn't do much more than a
> grid-snapping (plus some topological fixes of the snapping),
> basically exposing no real management of PrecisionModels...
> Are there tests to verify that ?
> REF: https://trac.osgeo.org/geos/ticket/713
> --strk;
> On Wed, Jan 14, 2015 at 10:38:23AM +0100, Sandro Santilli wrote:
> > On Tue, Jan 13, 2015 at 11:21:34AM +0100, Sandro Mani wrote:
> > > On 08.01.2015 13:08, Sandro Mani wrote:
> > > >So to wrap up, things currently look as follows (which I actually
> > > >think is quite neat!):
> > > >/** GEOSContextHandle_t internally keeps a reference count, set to
> > > >1 on creation
> > > > * - *All* methods producing a GEOSGeom increase the reference count
> > > > * - GEOSGeom_destroy decreses the GeometryFactory reference
> > > >count, if 0, it destroys the context
> > > > * - finishGEOS_r decreses the reference count, if 0, it destroys
> > > >the context
> > > >/** GEOSGeom_clone() clones the geometry and applies
> > > >PrecisionReducer::reduce
> > > > * if the PrecisionModel of the current context is different than
> > > >the that of
> > > > * the passed geometry
> > > >/** Set context handle precision model **/
> > > >void GEOSContextHandle_t
> > > >GEOSContext_setPrecisionDouble(GEOSContextHandle_t* handle);
> > > >GEOSContext_setPrecisionFixed(GEOSContextHandle_t* handle, double
> > > >scale);
> > > So, what do you think? Worth pursuing this approach?
> > Sorry I'm not having much time to dedicate to this.
> > I'm not very sure about the approach, to be honest.
> > There are indeed 2 possible things one would want to do with PM:
> > 1. "advertise" the PM of a geometry, w/out rounding coords
> > 2. "set" the PM of a geometry, rounding coords
> > I'm not sure we ever want to allow for 1, to avoid wrong advertisement.
> > The signature in the current proposal makes 2 clear for the cloning
> > of a geometry, but we're still missing clear documentation about what
> > happens from the constructors. Would/should they round ?
> > Example, what should happen here:
> > GEOSContextHandle_t h = initGEOS_r(...);
> > GEOSCoordSequence *s = GEOSCoordSeq_create_r(h,2,2);
> > GEOSContext_setPrecisionDouble(h);
> > GEOSCoordSeq_setX_r(h, s, 0, 0);
> > GEOSCoordSeq_setY_r(h, s, 0, 0);
> > GEOSContext_setPrecisionFixed(h, 1);
> > GEOSCoordSeq_setX_r(h, s, 1, 0.2);
> > GEOSCoordSeq_setY_r(h, s, 1, 0.2);
> > Should the coordinate sequence contain 2 equal points after the above ?
> > And what about WKB/WKT parsing ?
> > It would help to gather more comments from others.
> > I've added Oliver and Sean in Cc as they took part of a precedent
> > discussion about this:
> > http://lists.osgeo.org/pipermail/geos-devel/2014-February/006780.html
> > --strk;
> > () Free GIS & Flash consultant/developer
> > /\ http://strk.keybit.net/services.html
