[geos-devel] [GEOS] #741: [PATCH] GEOSSimplify() returns empty polygon if inner ring dimension < simplify distance
GEOS geos-trac at osgeo.org
Wed Oct 7 02:43:45 PDT 2015
simplify distance
 Reporter:  rouault     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.4.3
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by strk):
 Martin can you take a look at this, sounds sensible to me.
Ticket URL: <https://trac.osgeo.org/geos/ticket/741#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
