[geos-devel] [GEOS] #749: GeometryPrecisionReducer not honouring target PM
GEOS geos-trac at osgeo.org
Tue Oct 13 03:08:00 PDT 2015
 Reporter:  strk        |      Owner:  geos-devel@…
     Type:  defect      |     Status:  new
 Priority:  blocker     |  Milestone:  3.6.0
Component:  Default     |    Version:  svn-trunk
 Severity:  Unassigned  |   Keywords:
 This needs more testing but I've added a GEOSGeom_getPrecision function to
 the C-API and in some cases it's not confirming that the corresponding
 GEOSGeom_setPrecision did what it advertise to do.
 Adding debugging lines shows a possible bug in GeometryPrecisionReducer
 not properly setting the output model.
Ticket URL: <https://trac.osgeo.org/geos/ticket/749>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
