[geos-devel] [GEOS] #713: [Patch] Add GeometryPrecisionReducer to C API
GEOS geos-trac at osgeo.org
Wed Sep 30 10:42:27 PDT 2015
 Reporter:  smani       |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.4.3
Component:  Default     |     Version:  3.4.2
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by smani):
 The patch attached to this ticket is pretty much what I'm using in QGIS. I
 can create a pull request with that patch if that helps. The discussion on
 the mailing list deviated away from that patch towards a more implicit
 exposure of the precision reduction functionality, but the discussion
 stalled away with various issues with that idea still open. The patch
 attached to this ticket (and what is used in QGIS) is basically a straight
 1:1 port of the C++ api to C.
Ticket URL: <https://trac.osgeo.org/geos/ticket/713#comment:7>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
