[geos-devel] [GEOS] #775: Patch for nmake support for latest Visual Studio compiler (14.0)
GEOS geos-trac at osgeo.org
Tue Apr 5 08:28:37 PDT 2016
 Reporter:  jmckenna    |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:  3.5.1
Component:  Default     |     Version:  3.5.0
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Comment (by strk):
 Thanks Jeff, committed in trunk with r4180.
 Do you confirm I got it right ? (written manually as
 the downloaded patch didn't applie cleanly due to endline mismatches)
Ticket URL: <https://trac.osgeo.org/geos/ticket/775#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
