[geos-devel] [GEOS] #776: Port MinimumClearance from JTS
GEOS geos-trac at osgeo.org
Sun Apr 24 14:58:44 PDT 2016
 Reporter:  dbaston      |       Owner:  geos-devel@…
     Type:  enhancement  |      Status:  new
 Priority:  major        |   Milestone:  3.6.0
Component:  Default      |     Version:  svn-trunk
 Severity:  Unassigned   |  Resolution:
 Keywords:               |
Comment (by dbaston):
 I've implemented the PostGIS piece of this too
 (https://trac.osgeo.org/postgis/ticket/3424) and used it to stress-test
 this branch.  With an input set of ~120,000 polygons there are no
 differences between GEOS and JTS results.  Runtime is comparable.
Ticket URL: <https://trac.osgeo.org/geos/ticket/776#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
