[geos-devel] [GEOS] #787: geos-3.5.0 failure to build using MingW
GEOS geos-trac at osgeo.org
Fri Aug 26 08:08:08 PDT 2016
 Reporter:  ddurgaprasad  |      Owner:  geos-devel@…
     Type:  defect        |     Status:  new
 Priority:  major         |  Milestone:  3.5.1
Component:  Default       |    Version:  3.5.0
 Severity:  Unassigned    |   Keywords:  mingw
 Building geos-3.5.0 is failin gon Windows7 OS under Mingw environment.
 The configure commands works fine but make is failing.Below is the build
 log.
 mydomian+uid at myip MINGW64 /c/MinGW/git_rep/geos-3.5.0
 $ ./configure --build=x86_64-pc-linux-gnu --host=arm-linux-eabi
 checking build system type... x86_64-pc-linux-gnu
 checking host system type... arm-linux-eabi
 checking target system type... arm-linux-eabi
 checking for a BSD-compatible install... /usr/bin/install -c
 checking whether build environment is sane... yes
 checking for arm-linux-eabi-strip... no
 checking for strip... strip
 configure: WARNING: using cross tools not prefixed with host triplet
 checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
 checking for gawk... gawk
 checking whether make sets $(MAKE)... yes
 checking whether make supports nested variables... yes
 checking whether to enable maintainer-specific portions of Makefiles... no
 checking for arm-linux-eabi-gcc... no
 checking for gcc... gcc
 checking whether the C compiler works... yes
 checking for C compiler default output file name... a.exe
 checking for suffix of executables... .exe
 checking whether we are cross compiling... yes
 checking for suffix of object files... o
 checking whether we are using the GNU C compiler... yes
 checking whether gcc accepts -g... yes
 checking for gcc option to accept ISO C89... none needed
 checking whether gcc understands -c and -o together... yes
 checking for style of include used by make... GNU
 checking dependency style of gcc... gcc3
 checking how to print strings... printf
 checking for a sed that does not truncate output... /usr/bin/sed
 checking for grep that handles long lines and -e... /usr/bin/grep
 checking for egrep... /usr/bin/grep -E
 checking for fgrep... /usr/bin/grep -F
 checking for ld used by gcc... c:/mingw/mingw32/bin/ld.exe
 checking if the linker (c:/mingw/mingw32/bin/ld.exe) is GNU ld... yes
 checking for BSD- or MS-compatible name lister (nm)... no
 checking for arm-linux-eabi-dumpbin... no
 checking for arm-linux-eabi-link... no
 checking for dumpbin... dumpbin
 checking the name lister (dumpbin -symbols -headers) interface... MS
 dumpbin
 checking whether ln -s works... no, using cp -pR
 checking the maximum length of command line arguments... 24000
 checking how to convert x86_64-pc-linux-gnu file names to arm-linux-eabi
 format... func_convert_file_noop
 checking how to convert x86_64-pc-linux-gnu file names to toolchain
 checking for c:/mingw/mingw32/bin/ld.exe option to reload object files...
 -r
 checking for arm-linux-eabi-objdump... objdump
 checking how to recognize dependent libraries... unknown
 checking for arm-linux-eabi-dlltool... dlltool
 checking how to associate runtime and link libraries... printf %s\n
 checking for arm-linux-eabi-ar... no
 checking for ar... ar
 checking for archiver @FILE support... @
 checking for arm-linux-eabi-strip... strip
 checking for arm-linux-eabi-ranlib... no
 checking for ranlib... ranlib
 checking command to parse dumpbin -symbols -headers output from gcc
 object... ok
 checking for sysroot... no
 checking for a working dd... /usr/bin/dd
 checking how to truncate binary pipes... /usr/bin/dd bs=4096 count=1
 checking for arm-linux-eabi-mt... no
 checking for mt... no
 checking if : is a manifest tool... no
 checking how to run the C preprocessor... gcc -E
 checking for ANSI C header files... yes
 checking for sys/types.h... yes
 checking for sys/stat.h... yes
 checking for stdlib.h... yes
 checking for string.h... yes
 checking for memory.h... yes
 checking for strings.h... yes
 checking for inttypes.h... yes
 checking for stdint.h... yes
 checking for unistd.h... yes
 checking for dlfcn.h... yes
 checking for objdir... .libs
 checking if gcc supports -fno-rtti -fno-exceptions... no
 checking for gcc option to produce PIC... -fPIC -DPIC
 checking if gcc PIC flag -fPIC -DPIC works... no
 checking if gcc static flag -static works... yes
 checking if gcc supports -c -o file.o... yes
 checking if gcc supports -c -o file.o... (cached) yes
 checking whether the gcc linker (c:/mingw/mingw32/bin/ld.exe) supports
 shared libraries... yes
 checking whether -lc should be explicitly linked in... yes
 checking dynamic linker characteristics... no
 checking how to hardcode library paths into programs... immediate
 checking for shl_load... no
 checking for shl_load in -ldld... no
 checking for dlopen... yes
 checking whether a program can dlopen itself... cross
 checking whether stripping libraries is possible... yes
 checking if libtool supports shared libraries... no
 checking whether to build shared libraries... no
 checking whether to build static libraries... yes
 checking for arm-linux-eabi-g++... no
 checking for arm-linux-eabi-c++... no
 checking for arm-linux-eabi-gpp... no
 checking for arm-linux-eabi-aCC... no
 checking for arm-linux-eabi-CC... no
 checking for arm-linux-eabi-cxx... no
 checking for arm-linux-eabi-cc++... no
 checking for arm-linux-eabi-cl.exe... no
 checking for arm-linux-eabi-FCC... no
 checking for arm-linux-eabi-KCC... no
 checking for arm-linux-eabi-RCC... no
 checking for arm-linux-eabi-xlC_r... no
 checking for arm-linux-eabi-xlC... no
 checking for g++... g++
 checking whether we are using the GNU C++ compiler... yes
 checking whether g++ accepts -g... yes
 checking dependency style of g++... gcc3
 checking how to run the C++ preprocessor... g++ -E
 checking for ld used by g++... c:/mingw/mingw32/bin/ld.exe
 checking whether the g++ linker (c:/mingw/mingw32/bin/ld.exe) supports
 checking for g++ option to produce PIC... -fPIC -DPIC
 checking if g++ PIC flag -fPIC -DPIC works... no
 checking if g++ static flag -static works... yes
 checking if g++ supports -c -o file.o... yes
 checking if g++ supports -c -o file.o... (cached) yes
 checking for library containing strerror... none required
 checking whether make sets $(MAKE)... (cached) yes
 checking for dirent.h that defines DIR... yes
 checking for library containing opendir... none required
 checking whether closedir returns void... yes
 checking for working memcmp... no
 checking for strftime... yes
 checking for vprintf... yes
 checking for _doprnt... no
 checking for size_t... yes
 checking for working alloca.h... no
 checking for alloca... yes
 checking for dirent.h that defines DIR... (cached) yes
 checking for library containing opendir... (cached) none required
 checking for ANSI C header files... (cached) yes
 checking for memory.h... (cached) yes
 checking for unistd.h... (cached) yes
 checking ieeefp.h usability... no
 checking ieeefp.h presence... no
 checking for ieeefp.h... no
 checking sys/file.h usability... yes
 checking sys/file.h presence... yes
 checking for sys/file.h... yes
 checking sys/time.h usability... yes
 checking sys/time.h presence... yes
 checking for sys/time.h... yes
 checking for strchr... yes
 checking for memcpy... yes
 checking for gettimeofday... yes
 checking whether stat file-mode macros are broken... no
 checking whether struct tm is in sys/time.h or time.h... time.h
 checking for size_t... (cached) yes
 checking for an ANSI C-conforming const... yes
 checking if requested to force inline functions... yes
 checking if requested to enable assert macros... yes
 checking if requested libstdc++ debug mode... no
 checking if g++ supports -pedantic... yes
 checking if g++ supports -Wall... yes
 checking if g++ supports -ansi... yes
 checking if g++ supports -Wno-long-long... yes
 checking if g++ supports -ffloat-store... yes
 checking for finite... yes
 checking for isfinite... yes
 checking for isnan... no
 checking whether int64_t is 64 bits... no
 checking whether long long int is 64 bits... yes
 checking OS-specific settings... checking that generated files are newer
 than configure... done
 configure: creating ./config.status
 config.status: creating Makefile
 config.status: creating capi/Makefile
 config.status: creating capi/geos_c.h
 config.status: creating doc/Doxyfile
 config.status: creating doc/Makefile
 config.status: creating macros/Makefile
 config.status: creating src/Makefile
 config.status: creating src/algorithm/Makefile
 config.status: creating src/algorithm/locate/Makefile
 config.status: creating src/algorithm/distance/Makefile
 config.status: creating src/geom/Makefile
 config.status: creating src/geom/prep/Makefile
 config.status: creating src/geom/util/Makefile
 config.status: creating src/geomgraph/Makefile
 config.status: creating src/geomgraph/index/Makefile
 config.status: creating include/Makefile
 config.status: creating include/geos/Makefile
 config.status: creating include/geos/algorithm/Makefile
 config.status: creating include/geos/algorithm/locate/Makefile
 config.status: creating include/geos/algorithm/distance/Makefile
 config.status: creating include/geos/geom/Makefile
 config.status: creating include/geos/geom/prep/Makefile
 config.status: creating include/geos/geom/util/Makefile
 config.status: creating include/geos/geomgraph/Makefile
 config.status: creating include/geos/geomgraph/index/Makefile
 config.status: creating include/geos/index/Makefile
 config.status: creating include/geos/index/bintree/Makefile
 config.status: creating include/geos/index/chain/Makefile
 config.status: creating include/geos/index/intervalrtree/Makefile
 config.status: creating include/geos/index/quadtree/Makefile
 config.status: creating include/geos/index/strtree/Makefile
 config.status: creating include/geos/index/sweepline/Makefile
 config.status: creating include/geos/io/Makefile
 config.status: creating include/geos/linearref/Makefile
 config.status: creating include/geos/noding/Makefile
 config.status: creating include/geos/noding/snapround/Makefile
 config.status: creating include/geos/operation/Makefile
 config.status: creating include/geos/operation/buffer/Makefile
 config.status: creating include/geos/operation/distance/Makefile
 config.status: creating include/geos/operation/intersection/Makefile
 config.status: creating include/geos/operation/linemerge/Makefile
 config.status: creating include/geos/operation/overlay/Makefile
 config.status: creating include/geos/operation/overlay/snap/Makefile
 config.status: creating include/geos/operation/polygonize/Makefile
 config.status: creating include/geos/operation/predicate/Makefile
 config.status: creating include/geos/operation/relate/Makefile
 config.status: creating include/geos/operation/sharedpaths/Makefile
 config.status: creating include/geos/operation/union/Makefile
 config.status: creating include/geos/operation/valid/Makefile
 config.status: creating include/geos/planargraph/Makefile
 config.status: creating include/geos/planargraph/algorithm/Makefile
 config.status: creating include/geos/precision/Makefile
 config.status: creating include/geos/simplify/Makefile
 config.status: creating include/geos/triangulate/Makefile
 config.status: creating include/geos/triangulate/quadedge/Makefile
 config.status: creating include/geos/util/Makefile
 config.status: creating include/geos/version.h
 config.status: creating src/index/Makefile
 config.status: creating src/index/bintree/Makefile
 config.status: creating src/index/chain/Makefile
 config.status: creating src/index/intervalrtree/Makefile
 config.status: creating src/index/quadtree/Makefile
 config.status: creating src/index/strtree/Makefile
 config.status: creating src/index/sweepline/Makefile
 config.status: creating src/io/Makefile
 config.status: creating src/linearref/Makefile
 config.status: creating src/noding/Makefile
 config.status: creating src/noding/snapround/Makefile
 config.status: creating src/operation/Makefile
 config.status: creating src/operation/buffer/Makefile
 config.status: creating src/operation/distance/Makefile
 config.status: creating src/operation/intersection/Makefile
 config.status: creating src/operation/linemerge/Makefile
 config.status: creating src/operation/overlay/Makefile
 config.status: creating src/operation/polygonize/Makefile
 config.status: creating src/operation/predicate/Makefile
 config.status: creating src/operation/relate/Makefile
 config.status: creating src/operation/sharedpaths/Makefile
 config.status: creating src/operation/union/Makefile
 config.status: creating src/operation/valid/Makefile
 config.status: creating src/planargraph/Makefile
 config.status: creating src/precision/Makefile
 config.status: creating src/simplify/Makefile
 config.status: creating src/triangulate/Makefile
 config.status: creating src/triangulate/quadedge/Makefile
 config.status: creating src/util/Makefile
 config.status: creating swig/geos.i
 config.status: creating swig/Makefile
 config.status: creating swig/python/Makefile
 config.status: creating swig/python/tests/Makefile
 config.status: creating swig/ruby/Makefile
 config.status: creating swig/ruby/test/Makefile
 config.status: creating php/Makefile
 config.status: creating php/test/Makefile
 config.status: creating tests/Makefile
 config.status: creating tests/bigtest/Makefile
 config.status: creating tests/unit/Makefile
 config.status: creating tests/perf/Makefile
 config.status: creating tests/perf/operation/Makefile
 config.status: creating tests/perf/operation/buffer/Makefile
 config.status: creating tests/perf/operation/predicate/Makefile
 config.status: creating tests/perf/capi/Makefile
 config.status: creating tests/xmltester/Makefile
 config.status: creating tests/geostest/Makefile
 config.status: creating tests/thread/Makefile
 config.status: creating tools/Makefile
 config.status: creating tools/geos-config
 config.status: creating include/config.h
 config.status: include/config.h is unchanged
 config.status: creating include/geos/platform.h
 config.status: include/geos/platform.h is unchanged
 config.status: executing depfiles commands
 config.status: executing libtool commands
 Swig: false
 Python bindings: false
 Ruby bindings: false
 PHP bindings: false
 $ make
 top_srcdir=. sh ./tools/svn_repo_revision.sh
 Can't fetch local revision (neither .svn nor .git found)
 Not updating existing rev file at GEOS_SVN_REVISION
 /usr/bin/make  all-recursive
 make[1]: Entering directory `/mingw/git_rep/geos-3.5.0'
 Making all in include
 make[2]: Entering directory `/mingw/git_rep/geos-3.5.0/include'
 make[3]: Entering directory `/mingw/git_rep/geos-3.5.0/include'
 Making all in geos
 make[4]: Entering directory `/mingw/git_rep/geos-3.5.0/include/geos'
 make[5]: Entering directory `/mingw/git_rep/geos-3.5.0/include/geos'
 Making all in algorithm
 make[6]: Entering directory
 `/mingw/git_rep/geos-3.5.0/include/geos/algorithm'
 Making all in locate
 make[7]: Entering directory
 `/mingw/git_rep/geos-3.5.0/include/geos/algorithm/locate'
 make[8]: Entering directory
 make[8]: Nothing to be done for `all-am'.
 make[8]: Leaving directory
 make[7]: Leaving directory
 Making all in distance
 `/mingw/git_rep/geos-3.5.0/include/geos/algorithm/distance'
 make[7]: Nothing to be done for `all-am'.
 make[6]: Leaving directory
 Making all in geom
 make[6]: Entering directory `/mingw/git_rep/geos-3.5.0/include/geos/geom'
 Making all in util
 `/mingw/git_rep/geos-3.5.0/include/geos/geom/util'
 make[7]: Nothing to be done for `all'.
 Making all in prep
 `/mingw/git_rep/geos-3.5.0/include/geos/geom/prep'
 make[7]: Entering directory `/mingw/git_rep/geos-3.5.0/include/geos/geom'
 make[7]: Leaving directory `/mingw/git_rep/geos-3.5.0/include/geos/geom'
 make[6]: Leaving directory `/mingw/git_rep/geos-3.5.0/include/geos/geom'
 Making all in geomgraph
 `/mingw/git_rep/geos-3.5.0/include/geos/geomgraph'
 Making all in index
 `/mingw/git_rep/geos-3.5.0/include/geos/geomgraph/index'
 Making all in index
 make[6]: Entering directory `/mingw/git_rep/geos-3.5.0/include/geos/index'
 Making all in intervalrtree
 `/mingw/git_rep/geos-3.5.0/include/geos/index/intervalrtree'
 Making all in sweepline
 `/mingw/git_rep/geos-3.5.0/include/geos/index/sweepline'
 Making all in strtree
 `/mingw/git_rep/geos-3.5.0/include/geos/index/strtree'
 Making all in quadtree
 `/mingw/git_rep/geos-3.5.0/include/geos/index/quadtree'
 Making all in bintree
 `/mingw/git_rep/geos-3.5.0/include/geos/index/bintree'
 Making all in chain
 `/mingw/git_rep/geos-3.5.0/include/geos/index/chain'
 make[7]: Entering directory `/mingw/git_rep/geos-3.5.0/include/geos/index'
 make[7]: Leaving directory `/mingw/git_rep/geos-3.5.0/include/geos/index'
 make[6]: Leaving directory `/mingw/git_rep/geos-3.5.0/include/geos/index'
 Making all in io
 make[6]: Entering directory `/mingw/git_rep/geos-3.5.0/include/geos/io'
 make[7]: Entering directory `/mingw/git_rep/geos-3.5.0/include/geos/io'
 make[7]: Leaving directory `/mingw/git_rep/geos-3.5.0/include/geos/io'
 make[6]: Leaving directory `/mingw/git_rep/geos-3.5.0/include/geos/io'
 Making all in linearref
 `/mingw/git_rep/geos-3.5.0/include/geos/linearref'
 make[6]: Nothing to be done for `all'.
 Making all in noding
 `/mingw/git_rep/geos-3.5.0/include/geos/noding'
 Making all in snapround
 `/mingw/git_rep/geos-3.5.0/include/geos/noding/snapround'
 make[7]: Leaving directory `/mingw/git_rep/geos-3.5.0/include/geos/noding'
 make[6]: Leaving directory `/mingw/git_rep/geos-3.5.0/include/geos/noding'
 Making all in operation
 `/mingw/git_rep/geos-3.5.0/include/geos/operation'
 Making all in buffer
 `/mingw/git_rep/geos-3.5.0/include/geos/operation/buffer'
 `/mingw/git_rep/geos-3.5.0/include/geos/operation/distance'
 Making all in intersection
 `/mingw/git_rep/geos-3.5.0/include/geos/operation/intersection'
 Making all in linemerge
 `/mingw/git_rep/geos-3.5.0/include/geos/operation/linemerge'
 Making all in overlay
 `/mingw/git_rep/geos-3.5.0/include/geos/operation/overlay'
 Making all in snap
 `/mingw/git_rep/geos-3.5.0/include/geos/operation/overlay/snap'
 make[8]: Nothing to be done for `all'.
 Making all in polygonize
 `/mingw/git_rep/geos-3.5.0/include/geos/operation/polygonize'
 Making all in predicate
 `/mingw/git_rep/geos-3.5.0/include/geos/operation/predicate'
 Making all in relate
 `/mingw/git_rep/geos-3.5.0/include/geos/operation/relate'
 Making all in union
 `/mingw/git_rep/geos-3.5.0/include/geos/operation/union'
 Making all in sharedpaths
 `/mingw/git_rep/geos-3.5.0/include/geos/operation/sharedpaths'
 Making all in valid
 `/mingw/git_rep/geos-3.5.0/include/geos/operation/valid'
 Making all in planargraph
 `/mingw/git_rep/geos-3.5.0/include/geos/planargraph'
 `/mingw/git_rep/geos-3.5.0/include/geos/planargraph/algorithm'
 Making all in precision
 `/mingw/git_rep/geos-3.5.0/include/geos/precision'
 Making all in simplify
 `/mingw/git_rep/geos-3.5.0/include/geos/simplify'
 Making all in triangulate
 `/mingw/git_rep/geos-3.5.0/include/geos/triangulate'
 Making all in quadedge
 `/mingw/git_rep/geos-3.5.0/include/geos/triangulate/quadedge'
 Making all in util
 make[6]: Entering directory `/mingw/git_rep/geos-3.5.0/include/geos/util'
 make[6]: Leaving directory `/mingw/git_rep/geos-3.5.0/include/geos/util'
 make[6]: Entering directory `/mingw/git_rep/geos-3.5.0/include/geos'
 make[6]: Leaving directory `/mingw/git_rep/geos-3.5.0/include/geos'
 make[5]: Leaving directory `/mingw/git_rep/geos-3.5.0/include/geos'
 make[4]: Leaving directory `/mingw/git_rep/geos-3.5.0/include/geos'
 make[4]: Entering directory `/mingw/git_rep/geos-3.5.0/include'
 make[4]: Leaving directory `/mingw/git_rep/geos-3.5.0/include'
 make[3]: Leaving directory `/mingw/git_rep/geos-3.5.0/include'
 make[2]: Leaving directory `/mingw/git_rep/geos-3.5.0/include'
 Making all in src
 make[2]: Entering directory `/mingw/git_rep/geos-3.5.0/src'
 make[3]: Entering directory `/mingw/git_rep/geos-3.5.0/src/algorithm'
 `/mingw/git_rep/geos-3.5.0/src/algorithm/locate'
 /bin/sh ../../../libtool  --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H
 -I. -I../../../include -I../../../include/geos  -I../../../include
 -DGEOS_INLINE  -pedantic -Wall -ansi -Wno-long-long  -ffloat-store -g -O2
 -MT IndexedPointInAreaLocator.lo -MD -MP -MF
 .deps/IndexedPointInAreaLocator.Tpo -c -o IndexedPointInAreaLocator.lo
 IndexedPointInAreaLocator.cpp
 libtool: compile:  g++ -DHAVE_CONFIG_H -I. -I../../../include
 -I../../../include/geos -I../../../include -DGEOS_INLINE -pedantic -Wall
 -ansi -Wno-long-long -ffloat-store -g -O2 -MT IndexedPointInAreaLocator.lo
 -MD -MP -MF .deps/IndexedPointInAreaLocator.Tpo -c
 IndexedPointInAreaLocator.cpp -o IndexedPointInAreaLocator.o
 In file included from c:\mingw\include\wchar.h:208:0,
                  from
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar:44,
                  from
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\bits\postypes.h:40,
                  from
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\bits\char_traits.h:40,
                  from
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\string:40,
                  from ../../../include/geos/geom/Coordinate.h:24,
                  from ../../../include/geos/geom/Envelope.h:25,
                  from ../../../include/geos/geom/Geometry.h:27,
                  from IndexedPointInAreaLocator.cpp:17:
 c:\mingw\include\sys/stat.h:173:14: error: '_dev_t' does not name a type
  struct _stat __struct_stat_defined( _off_t, time_t );
 c:\mingw\include\sys/stat.h:173:14: error: '_ino_t' does not name a type
 c:\mingw\include\sys/stat.h:173:14: error: '_mode_t' does not name a type
 c:\mingw\include\sys/stat.h:173:14: error: '_off_t' does not name a type
 c:\mingw\include\sys/stat.h:173:14: error: 'time_t' does not name a type
 c:\mingw\include\sys/stat.h:180:13: error: '_dev_t' does not name a type
  struct stat __struct_stat_defined( _off_t, time_t );
 c:\mingw\include\sys/stat.h:180:13: error: '_ino_t' does not name a type
 c:\mingw\include\sys/stat.h:180:13: error: '_mode_t' does not name a type
 c:\mingw\include\sys/stat.h:180:13: error: '_off_t' does not name a type
 c:\mingw\include\sys/stat.h:180:13: error: 'time_t' does not name a type
 c:\mingw\include\sys/stat.h:188:17: error: '_dev_t' does not name a type
  struct _stati64 __struct_stat_defined( __off64_t, time_t );
 c:\mingw\include\sys/stat.h:188:17: error: '_ino_t' does not name a type
 c:\mingw\include\sys/stat.h:188:17: error: '_mode_t' does not name a type
 c:\mingw\include\sys/stat.h:188:17: error: '__off64_t' does not name a
 type
 c:\mingw\include\sys/stat.h:188:17: error: 'time_t' does not name a type
 c:\mingw\include\sys/stat.h:195:17: error: '_dev_t' does not name a type
  struct __stat64 __struct_stat_defined( __off64_t, __time64_t );
 c:\mingw\include\sys/stat.h:195:17: error: '_ino_t' does not name a type
 c:\mingw\include\sys/stat.h:195:17: error: '_mode_t' does not name a type
 c:\mingw\include\sys/stat.h:195:17: error: '__off64_t' does not name a
 type
 c:\mingw\include\sys/stat.h:195:17: error: '__time64_t' does not name a
 type
 type
 type
 In file included from c:\mingw\include\wchar.h:233:0,
                  from
                  from
                  from
                  from
 c:\mingw\include\io.h:335:21: error: 'time_t' does not name a type
  struct _wfinddata_t __struct_finddata_t (time_t, _fsize_t);
 c:\mingw\include\io.h:336:24: error: 'time_t' does not name a type
  struct _wfinddatai64_t __struct_finddata_t (time_t, __int64);
 c:\mingw\include\io.h:362:24: error: '__time64_t' does not name a type
  struct __wfinddata64_t __struct_finddata_t (__time64_t, __int64);
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\bits\postypes.h:40:0,
                  from
                  from
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar:146:11: error: '::fwide'
 has not been declared
    using ::fwide;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar:153:11: error:
 '::mbsinit' has not been declared
    using ::mbsinit;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar:164:11: error:
 '::vfwscanf' has not been declared
    using ::vfwscanf;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar:170:11: error:
 '::vswscanf' has not been declared
    using ::vswscanf;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar:174:11: error:
 '::vwscanf' has not been declared
    using ::vwscanf;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar:191:11: error:
 '::wcstof' has not been declared
    using ::wcstof;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar:198:11: error:
 '::wmemcmp' has not been declared
    using ::wmemcmp;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar:199:11: error:
 '::wmemcpy' has not been declared
    using ::wmemcpy;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar:200:11: error:
 '::wmemmove' has not been declared
    using ::wmemmove;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar:201:11: error:
 '::wmemset' has not been declared
    using ::wmemset;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar:208:11: error:
 '::wmemchr' has not been declared
    using ::wmemchr;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar: In function 'wchar_t*
 std::wmemchr(wchar_t*, wchar_t, std::size_t)':
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar:229:61: error: invalid
 conversion from 'const wchar_t*' to 'wchar_t*' [-fpermissive]
    { return wmemchr(const_cast<const wchar_t*>(__p), __c, __n); }
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar: At global scope:
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar:248:11: error:
 '::wcstold' has not been declared
    using ::wcstold;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar:257:11: error:
 '::wcstoll' has not been declared
    using ::wcstoll;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar:258:11: error:
 '::wcstoull' has not been declared
    using ::wcstoull;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar:264:22: error:
 '__gnu_cxx::wcstold' has not been declared
    using ::__gnu_cxx::wcstold;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar:265:22: error:
 '__gnu_cxx::wcstoll' has not been declared
    using ::__gnu_cxx::wcstoll;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cwchar:266:22: error:
 '__gnu_cxx::wcstoull' has not been declared
    using ::__gnu_cxx::wcstoull;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\string:40:0,
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\bits\char_traits.h: In static
 member function 'static int std::char_traits<wchar_t>::compare(const
 char_type*, const char_type*, std::size_t)':
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\bits\char_traits.h:330:39:
 error: 'wmemcmp' was not declared in this scope
        { return wmemcmp(__s1, __s2, __n); }
 member function 'static const char_type*
 std::char_traits<wchar_t>::find(const char_type*, std::size_t, const
 char_type&)':
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\bits\char_traits.h:338:37:
 error: invalid conversion from 'const char_type* {aka const wchar_t*}' to
        { return wmemchr(__s, __a, __n); }
 member function 'static std::char_traits<wchar_t>::char_type*
 std::char_traits<wchar_t>::move(std::char_traits<wchar_t>::char_type*,
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\bits\char_traits.h:342:40:
 error: 'wmemmove' was not declared in this scope
        { return wmemmove(__s1, __s2, __n); }
 std::char_traits<wchar_t>::copy(std::char_traits<wchar_t>::char_type*,
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\bits\char_traits.h:346:39:
 error: 'wmemcpy' was not declared in this scope
        { return wmemcpy(__s1, __s2, __n); }
 std::char_traits<wchar_t>::assign(std::char_traits<wchar_t>::char_type*,
 std::size_t, std::char_traits<wchar_t>::char_type)':
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\bits\char_traits.h:350:37:
 error: 'wmemset' was not declared in this scope
        { return wmemset(__s, __a, __n); }
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\bits\stl_algo.h:59:0,
                  from
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\algorithm:62,
                  from IndexedPointInAreaLocator.cpp:29:
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib: At global scope:
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib:201:11: error:
 '::lldiv_t' has not been declared
    using ::lldiv_t;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib:207:11: error:
 '::_Exit' has not been declared
    using ::_Exit;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib:211:11: error:
 '::llabs' has not been declared
    using ::llabs;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib:213:10: error:
 'lldiv_t' does not name a type
    inline lldiv_t
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib:217:11: error:
 '::lldiv' has not been declared
    using ::lldiv;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib:228:11: error:
 '::atoll' has not been declared
    using ::atoll;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib:229:11: error:
 '::strtoll' has not been declared
    using ::strtoll;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib:230:11: error:
 '::strtoull' has not been declared
    using ::strtoull;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib:232:11: error:
 '::strtof' has not been declared
    using ::strtof;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib:233:11: error:
 '::strtold' has not been declared
    using ::strtold;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib:241:22: error:
 '__gnu_cxx::lldiv_t' has not been declared
    using ::__gnu_cxx::lldiv_t;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib:243:22: error:
 '__gnu_cxx::_Exit' has not been declared
    using ::__gnu_cxx::_Exit;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib:245:22: error:
 '__gnu_cxx::llabs' has not been declared
    using ::__gnu_cxx::llabs;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib:246:22: error:
 '__gnu_cxx::div' has not been declared
    using ::__gnu_cxx::div;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib:247:22: error:
 '__gnu_cxx::lldiv' has not been declared
    using ::__gnu_cxx::lldiv;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib:249:22: error:
 '__gnu_cxx::atoll' has not been declared
    using ::__gnu_cxx::atoll;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib:250:22: error:
 '__gnu_cxx::strtof' has not been declared
    using ::__gnu_cxx::strtof;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib:251:22: error:
 '__gnu_cxx::strtoll' has not been declared
    using ::__gnu_cxx::strtoll;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib:252:22: error:
 '__gnu_cxx::strtoull' has not been declared
    using ::__gnu_cxx::strtoull;
 c:\mingw\lib\gcc\mingw32\4.9.3\include\c++\cstdlib:253:22: error:
 '__gnu_cxx::strtold' has not been declared
    using ::__gnu_cxx::strtold;
 make[5]: *** [IndexedPointInAreaLocator.lo] Error 1
 make[4]: *** [all-recursive] Error 1
 make[3]: *** [all-recursive] Error 1
 make[3]: Leaving directory `/mingw/git_rep/geos-3.5.0/src/algorithm'
 make[2]: *** [all-recursive] Error 1
 make[2]: Leaving directory `/mingw/git_rep/geos-3.5.0/src'
 make[1]: *** [all-recursive] Error 1
 make[1]: Leaving directory `/mingw/git_rep/geos-3.5.0'
 make: *** [all] Error 2
Ticket URL: <https://trac.osgeo.org/geos/ticket/787>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
