[geos-devel] [GEOS] #741: [PATCH] GEOSSimplify() returns empty polygon if inner ring dimension < simplify distance
geos-trac at osgeo.org
Fri Dec 2 05:58:47 PST 2016
simplify distance
Reporter: rouault | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.6.1
Component: Default | Version: svn-trunk
Severity: Unassigned | Resolution:
Keywords: |
Comment (by strk):
In [changeset:"4311" 4311]:
#!CommitTicketReference repository="" revision="4311"
Fix empty GEOSSimplify return on inner ring collapse
Patch by Even Rouault
See #741
Ticket URL: <https://trac.osgeo.org/geos/ticket/741#comment:7>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
