[geos-devel] [GEOS] #767: "definitely lost" memory leak in rgeos_Init (rgeos.c:57)
geos-trac at osgeo.org
Thu Feb 4 01:59:22 PST 2016
Reporter: philae | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.5.1
Component: Default | Version: 3.5.0
Severity: Significant | Keywords: leak,rgeos,rgeos_Init,rgeos.c
Dear GEOS maintainers,
Thanks for this great software!
I would like to file a bug spotted via Valgrind while loading the R rgeos
package. Below are the steps to reproduce it.
=== Create an R script "load_only.R" to attach the package
> require("rgeos")
=== Run and debug the script using Valgring (Bash Shell)
{{{#!bash
$ R -d "valgrind --leak-check=full --show-reachable=yes --leak-check=full
--leak-resolution=high --show-leak-kinds=all --errors-for-leak-kinds=all
--log-file=logs" -f load_only.R
Valgring reports the following about the leak (I sanitized some paths
marked as SANITIZED_PATH and R-LIB_PATH):
40 bytes in 1 blocks are definitely lost in loss record 31 of 2,297
at 0x4C28C50: malloc (in SANITIZED_PATH/valgrind/vgpreload_memcheck-
amd64-linux.so)
by 0x16525093: initGEOS_r (in SANITIZED_PATH/libgeos_c.so.1.8.2)
by 0x15F5E738: rgeos_Init (rgeos.c:57)
by 0x4F0B34F: ??? (in R-LIB_PATH/R/lib/libR.so)
by 0x4F419DF: Rf_eval (in R-LIB_PATH/R/lib/libR.so)
by 0x4F43E87: ??? (in R-LIB_PATH/R/lib/libR.so)
by 0x4F417D0: Rf_eval (in R-LIB_PATH/R/lib/libR.so)
by 0x4F42E3D: Rf_applyClosure (in R-LIB_PATH/R/lib/libR.so)
by 0x4F415AC: Rf_eval (in R-LIB_PATH/R/lib/libR.so)
by 0x4F41CDA: ??? (in R-LIB_PATH/R/lib/libR.so)
by 0x4F41A3E: Rf_eval (in R-LIB_PATH/R/lib/libR.so)
The R session data is:
{{{#!r
packageVersion("rgeos")
[1] ‘0.3.15’
{{{#!r
xxx <- sessionInfo()
xxx$R.version$version.string
[1] "R version 3.2.3 (2015-12-10)"
{{{#!r
xxx$platform
[1] "x86_64-redhat-linux-gnu (64-bit)"
Ticket URL: <http://trac.osgeo.org/geos/ticket/767>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
