[geos-devel] [GEOS] #767: "definitely lost" memory leak in rgeos_Init (rgeos.c:57)
Roger Bivand
Roger.Bivand at nhh.no
Fri Feb 5 00:38:19 PST 2016
On Fri, 5 Feb 2016, Sandro Santilli wrote:
> Thanks Roger, could you provide an URL to the "rgeos"
> bug tracker as a reference ? Having this rationale as a comment
> on trac would also be nice. TIA
> https://trac.osgeo.org/geos/ticket/767
There is no bug tracker. General practice for all contributed R packages
(almost 8000) is to email the maintainer, whose email is in the package,
and on the archive network package page.
> packageDescription("rgeos")$Maintainer
[1] "Roger Bivand <Roger.Bivand at nhh.no>"
This is typically what happens, but in the R-spatial community, it is
equally OK to post on R-sig-geo:
https://stat.ethz.ch/mailman/listinfo/r-sig-geo
which may draw in other comments about user misunderstandings (being an
interpreted language, these do happen).
The rgeos development repo is at:
https://r-forge.r-project.org/projects/rgeos/
but the "lists" there are never used, as the developers all follow
R-sig-geo closely. Questioners may be asked to check attempts to fix
issues by installing from source from the repo; rgeos fails to build on
R-Forge because no GEOS binaries are available there so direct installs
from R-Forge do not work.
In summary - post on R-sig-geo after subscription, and follow the posting
guide with a reproducible example.
In this case as far as I can see, there is no link between the real issue
(use of rgeos through another R package under Windows on CP1252 apparently
switching locale), and the possible valgrind false positive.
valgrind may not be "seeing" all of the behaviour of the R garbage
collector; the 40 bytes are probably the GEOSContextHandle_t r stored as
an R_ExternalPtr and under the control of the R garbage collector
(alternatively something in the errorHandler or the warningHandler). The
handle is properly registered with a finalizer, so unloading the package
on R quit will free the pointer when the GC gets to it.
Thanks for taking an interest in an issue which appears to point somewhere
else - I've asked for a fully reproducible example to see where the locale
switching kicks in.
Roger
> --strk;
> On Thu, Feb 04, 2016 at 11:30:23PM +0100, Roger Bivand wrote:
>>> I would like to file a bug spotted via Valgrind while loading the R
>>> rgeos package. Below are the steps to reproduce it.
>> This is obviously not a GEOS issue, but should have been sent to the
>> maintainer of the rgeos package, that is to me. I have resolved the ticket
>> as invalid.
>> The identity of "philae" is unknown and untraceable - please contact
>> me directly including the test script, which wasn't attached to the
>> ticket.
>> A minor leakage of 40 bytes isn't a big deal, and its origin isn't clear.
>> Roger
>> Roger Bivand
>> Department of Economics, Norwegian School of Economics,
>> Helleveien 30, N-5045 Bergen, Norway.
>> voice: +47 55 95 93 55; fax +47 55 95 91 00
>> e-mail: Roger.Bivand at nhh.no
>> http://orcid.org/0000-0003-2392-6140
>> https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
>> http://depsy.org/person/434412
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
Roger Bivand
