[geos-devel] Ticket updates via commit logs
Sandro Santilli
strk at keybit.net
Mon Feb 22 09:49:02 PST 2016
I've just enabled ticket updates via commit logs for GEOS.
This means you can manage trac tickets using the following syntax
(copy & pasted from admin help)
---8<----------------------------------------------------------------
command #1
command #1, #2
command #1 & #2
command #1 and #2
Instead of the short-hand syntax "#1", "ticket:1" can be used as well,
e.g.:
command ticket:1
command ticket:1, ticket:2
command ticket:1 & ticket:2
command ticket:1 and ticket:2
In addition, the ':' character can be omitted and issue or bug can be
used instead of ticket.
You can have more than one command in a message. The following
commands are supported. There is more than one spelling for each
command, to make this as user-friendly as possible.
close, closed, closes, fix, fixed, fixes
The specified tickets are closed, and the commit message is added
to them as a comment.
references, refs, addresses, re, see
The specified tickets are left in their current status, and the
commit message is added to them as a comment.
A fairly complicated example of what you can do is with a commit
message of:
Changed blah and foo to do this or that. Fixes #10 and #12, and
refs #12.
This will close #10 and #12, and add a note to #12.
Have fun !
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
