[geos-devel] Union of linestrings
Mateusz Loskot mateusz at loskot.net
Mon Feb 29 10:18:08 PST 2016
I've started adding tests for OverlayOp [1] and I noticed
curious results for basic test case.
OverlayOp(UNION) on Four segments of a sqare
always construct a MultiLineString.
I'd have expected a polygon, shouldn't I?
In this case, I noticed OverlayOp always labels edges
as UNDEF or BOUNDARY this simply leads to non-area
results and the PolygonBuilder never receives any input
which qualifies as a polygon.
As you can see in the test, the union is constructed
incrementally:
GeometryPtr lines12(line1->Union(line2.get()));
GeometryPtr lines123(lines12->Union(line3.get()));
GeometryPtr lines1234(lines123->Union(line4.get()));
but the same result (MultiLineString) is returned
if I union via UnaryUnion on MultiLineString or GeometryCollection.
My questions are:
1. Is this expected behaviour?
2. Am I missing any trick to actually obtain the polygon?
[1] https://trac.osgeo.org/geos/changeset/4153
Best regards,
Mateusz Łoskot, http://mateusz.loskot.net
