[geos-devel] [GEOS] #762: Compiling error on cygwin
geos-trac at osgeo.org
Fri Jan 15 02:49:45 PST 2016
Reporter: jingsam | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.5.1
Component: Default | Version: 3.5.0
Severity: Unassigned | Keywords:
When I tried to compile geos on cygwin, errors occur:
geos_ts_c.cpp: in fucntion ‘void
GEOSContextHandle_HS::NOTICE_MESSAGE(std::string, ...)’:
geos_ts_c.cpp:228:81: error:‘vsnprintf’ undeclared in the context
int result = vsnprintf(msgBuffer, sizeof(msgBuffer) - 1,
fmt.c_str(), args);
geos_ts_c.cpp: in function ‘void
GEOSContextHandle_HS::ERROR_MESSAGE(std::string, ...)’中:
geos_ts_c.cpp:249:81: error:‘vsnprintf’ undeclared in the context
fmt.c_str(), args);
That may be caused by the non-existence of vsnprintf() which is a c++11
function.
g++ version: 4.9.3
Ticket URL: <https://trac.osgeo.org/geos/ticket/762>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
