[geos-devel] [GEOS] #762: Compiling error on cygwin
GEOS geos-trac at osgeo.org
Sat Jan 16 07:59:56 PST 2016
 Reporter:  jingsam     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.5.1
Component:  Default     |     Version:  3.5.0
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by jingsam):
 I got it.
 I checked the compiling command as fellows:
 g++ -DHAVE_CONFIG_H -I. -I../include -I../include/geos -I../include
 -DGEOS_CAPI_VERSION=\"3.5.0-CAPI-1.9.0\" -DGEOS_JTS_PORT=\"1.13.0\"
 -DGEOS_INLINE -pedantic -Wall '''-ansi''' -Wno-long-long -ffloat-store -g
 -O2 -MT libgeos_c_la-geos_ts_c.lo -MD -MP -MF .deps/libgeos_c_la-
 geos_ts_c.Tpo -c geos_ts_c.cpp  -DDLL_EXPORT -DPIC -o .libs/libgeos_c_la-
 geos_ts_c.o
 The tag "-ansi" is equivalent to "-std=c++98". The function "vsnprintf()"
 is not implemented in ansi standard. I think GEOS should adjust the
 compiling command.
Ticket URL: <http://trac.osgeo.org/geos/ticket/762#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
