[geos-devel] [GEOS] #764: PreparedPoint::intersects gives incorrect results for MultiPoint
geos-trac at osgeo.org
Tue Jan 19 17:52:56 PST 2016
Reporter: dbaston | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.5.1
Component: Default | Version: 3.5.0
Severity: Unassigned | Keywords:
It seems that if a PreparedPoint is build from a MultiPoint, intersects()
will return false for any point, for two independent reasons.
a) PreparedPoint::intersects short-circuits to an equality test. It looks
like this was introduced at r4081 / r4132.
b) the isAnyTargetComponentInTest method does its work using a
PointLocator, which seems to have no implementation for a Point.
Ticket URL: <https://trac.osgeo.org/geos/ticket/764>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
