[geos-devel] Extraction of PHP extension into PECL-style package
Sandro Santilli
strk at keybit.net
Wed Jan 20 14:29:43 PST 2016
On Wed, Jan 20, 2016 at 04:58:56PM -0500, J Smith wrote:
> On Wed, Jan 20, 2016 at 3:40 PM, Sandro Santilli <strk at keybit.net> wrote:
> > https://github.com/libgeos/php-geos
> > https://gitlab.com/geos/php-geos
> I'll let you know when I've made the necessary changes and merged my
> repo into this one. I'll also fix up the test files so they run as
> phpt tests and make sure they're running. They all ran on my machine
> with a bit of tweaking, but I'll take a look at some other extensions
> and see how they run their tests and modify accordingly.
FYI: I've also set-up an experimental git repo on osgeo, if
you want to set it as a remote too:
git://git.osgeo.org/php-geos
No trac instance was setup to go with it though, as I plan to experiment
hooking it up the existing GEOS trac instance.
--strk;
