[geos-devel] src/libgeos.la missing from tests/perf/Makefile.in
Sandro Santilli strk at kbt.io
Fri Jul 8 09:05:03 PDT 2016
On Fri, Jul 08, 2016 at 11:55:18AM +0100, Andrew Watkins wrote:
> I have tracked it down that the Makefile.in is missing libgeos.la
> geos-3.5.0-origin/tests/perf/Makefile.in geos-3.5.0/tests/perf/Makefile.in
> 278c278
> < LIBS = @LIBS@
> > LIBS = $(top_builddir)/src/libgeos.la
> Not sure how it works with GNU, but I wonder if the above is correct.
@LIBS@ should be expanded by the ./configure call
(How) is it expanded ?
--strk;
