[geos-devel] [GEOS] #784: g++ 6 isnan issues
geos-trac at osgeo.org
Thu Jul 14 04:27:39 PDT 2016
Reporter: rsbivand | Owner: geos-devel@…
Type: defect | Status: closed
Priority: blocker | Milestone: 3.5.1
Component: Default | Version: 3.5.0
Severity: Unassigned | Resolution: fixed
Keywords: |
Comment (by strk):
In [changeset:"4227" 4227]:
#!CommitTicketReference repository="" revision="4227"
Look for isnan in std:: namespace
Fully qualify isnan call when HAVE_ISNAN is defined
Tested with gcc 4.8.4
Fixes build with GCC-5.3.0 and higher.
Closes #784
Ticket URL: </ticket/784#comment:6>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
