[geos-devel] GeometryFilter vs GeometryComponentFilter on GeometryCollection
Mateusz Loskot
mateusz at loskot.net
Sat Mar 5 15:27:11 PST 2016
On 4 March 2016 at 15:44, Sandro Santilli <strk at keybit.net> wrote:
> On Fri, Mar 04, 2016 at 02:02:22PM +0100, Mateusz Loskot wrote:
>> Is this intentional that both filters pass the root geometry
>> (containing GeometryCollection or Multi*)
>> itself to apply_rw and apply_ro?
> I'd think the component filter should pass components, rather
> than the root, but might be missing something. Did you check if
> the class is used at all in the current codebase?
No, I simply implemented my own filters and compared the result.
I have just added new tests based on those filters
http://trac.osgeo.org/geos/changeset/4162
I included TODO comment wherever results are unclear to me.
I'll appreciate help in the actual vs expected results verification.
> Are there unit tests in JTS covering those classes ?
I have checked JTS current master [1] and I don't see any
tests for any of the filters.
[1] https://github.com/dr-jts/jts
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
