[geos-devel] git/osgeo repo for GEOS up read-only
Sandro Santilli
strk at keybit.net
Tue Mar 15 11:40:03 PDT 2016
Now also hooked on trac:
https://trac.osgeo.org/geos/browser/git
Next stop: turning SVN into read-only mode
--strk;
On Tue, Mar 15, 2016 at 10:49:34AM +0100, Sandro Santilli wrote:
> Following recent thread I've created a git repository
> for GEOS on the OSGeo machines.
> It can be accessed in read-only mode via:
> git://git.osgeo.org/geos
> The repository is kept up-to-date with the same script
> that syncronizes the gitlab.com and github.com mirrors
> so it is not yet ready for pushing into (except by the
> script keeping it in sync).
> If you promise not to push in any of the SVN branches,
> you can do so using this url:
> https://git.osgeo.org/git/geos
> You need to authenticate yourself as an OSGeo user in
> the "geos" group in order to push to that repo, if you
> want to avoid git to keep asking your username/password
> on every operation you can store your credentials on
> disk, simplest way to do that would be:
> git config credential.helper store
> Which would write your credentials (next time you enter
> them) into a ~/.git-credentials file.
> --strk;
> () Free GIS & Flash consultant/developer
> /\ http://strk.keybit.net/services.html
