[geos-devel] [GEOS] #796: GEOSSTRtree_nearest_r implementation missing from CAPI
geos-trac at osgeo.org
Wed Nov 9 23:31:21 PST 2016
Reporter: darkpanda | Owner: dbaston
Type: defect | Status: new
Priority: major | Milestone: 3.6.1
Component: Default | Version: 3.6.0
Severity: Unassigned | Resolution:
Keywords: |
Changes (by strk):
* owner: geos-devel@… => dbaston
Comment:
The function was added via https://github.com/libgeos/libgeos/pull/61 as
per #768
Daniel: can you take a look at this ?
BTW: we really need to put the reentrant API under unit testing !
Ticket URL: <https://trac.osgeo.org/geos/ticket/796#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
