[geos-devel] GEOS-3.6.0 released
Even Rouault even.rouault at spatialys.com
Tue Oct 25 13:00:06 PDT 2016
Le mardi 25 octobre 2016 21:43:05, Jeff McKenna a écrit :
> On 2016-10-25 4:23 PM, Sebastiaan Couwenberg wrote:
> > On 10/25/2016 06:07 PM, Sandro Santilli wrote:
> >>   - C++ API changes:
> >>     - Automatic memory management for GeometryFactory objects
> > This change seems to cause the build failures for OSSIM, osmium &
> > osm2pgsql with GEOS 3.6.0. All three builds fail with these errors:
> >  'geos::geom::GeometryFactory::GeometryFactory()' is protected within
> > this context
> >  'virtual geos::geom::GeometryFactory::~GeometryFactory()' is protected
> > within this context
> > What is the proper way to support GeometryFactory for both GEOS 3.5.0
> > and 3.6.0?
> Bas I was also confused (as a packager) seeing these 2 releases come
> out, and not sure how all of the many other projects handle the 3.6.0
> changes (like GDAL, MapServer, PostGIS etc.).
Haven't tried any of 2 new releases, but GDAL, MapServer and PostGIS use the
GEOS C API, so from the changelogs, shouldn't be affected by the 3.6.0 C++
change.
> So I'm assuming that
> packagers like us Bas are to use 3.5.1 for now?
> -jeff
http://www.spatialys.com
