[geos-devel] [GEOS] #778: Generate ChangeLog from git log
GEOS geos-trac at osgeo.org
Thu Oct 27 07:16:48 PDT 2016
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  task        |      Status:  new
 Priority:  major       |   Milestone:  3.7.0
Component:  Default     |     Version:  3.5.0
 Severity:  Unassigned  |  Resolution:
 Keywords:  git         |
Comment (by strk):
 In [changeset:"4282" 4282]:
 #!CommitTicketReference repository="" revision="4282"
 Remove ChangeLog from repository.
 The file will be created by "make dist" from either git
 (if .git exists) or svn (if .svn exists).
 Tested with builds from package, from source dir and from
 external build dir. Only automake.
 See #778
Ticket URL: </ticket/778#comment:12>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
