[geos-devel] [GEOS] #790: Memory leak in WKBReader.read?
GEOS geos-trac at osgeo.org
Sun Sep 25 01:37:19 PDT 2016
 Reporter:  edzer       |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.5.1
Component:  Default     |     Version:  3.5.0
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by strk):
 Check test/unit/io/WKBReaderTest.cpp, is your test doing things
 differently ?
 Run with {{{ libtool --mode=execute valgrind ./geos_unit
 geos::io::WKBReader }}} to ask valgrind about leaks generated there.
Ticket URL: <https://trac.osgeo.org/geos/ticket/790#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
