[geos-devel] [GEOS] #794: Rename geos_svn_revision.h to geos_revision.h, generate from git
GEOS geos-trac at osgeo.org
Sat Apr 1 04:01:10 PDT 2017
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  GEOS Future
Component:  Default     |     Version:
 Severity:  Unassigned  |  Resolution:
 Keywords:  git         |
Comment (by strk):
 In [changeset:"4392" 4392]:
 #!CommitTicketReference repository="" revision="4392"
 Turn GEOS_REVISION value into a string
 Propedeutic to optionally use an hash in there, or other non-SVN
 identifiers (see #794)
Ticket URL: <https://trac.osgeo.org/geos/ticket/794#comment:5>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
