[geos-devel] trailing blanks (was: Breeding .editorconfig is bad)
    Sandro Santilli
    strk at kbt.io
    Fri Apr  7 04:58:49 PDT 2017
On Fri, Apr 07, 2017 at 01:35:03PM +0200, Sandro Santilli wrote:
> The way I've been addressing those cases has been first committing
> removal of trailing blank spaces and then committing a separate
> funtional change.
I've tried removing all trailing blanks from .cpp and .h files
across the whole geos codebase, to get a feel of what it would
take.
The change summary is:
 753 files changed, 3219 insertions(+), 3219 deletions(-)
That's over a total of 156972 lines in 839 files, so 2% of the lines
in 90% of the files have trailing blanks.
Full change stats: http://strk.kbt.io/tmp/trailing-blanks.txt
I think 2% might be an acceptable loss for git-blame, what do you
think ? And we could then add a step in "make check" to make sure
no trailing blanks get back in the codebase.
Opinions ?
--strk;
