[geos-devel] [GEOS] #444: error compiling geos
GEOS geos-trac at osgeo.org
Sat Apr 8 09:22:39 PDT 2017
 Reporter:  aperi2007   |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  blocker     |   Milestone:  3.3.0
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"de3c6be997d18568677647d25f13ae9c2691e6f4/git"
 de3c6be9/git]:
 #!CommitTicketReference repository="git"
 revision="de3c6be997d18568677647d25f13ae9c2691e6f4"
 Do not assume isfinite is in std:: namespace to fix #444; Have
 RobustDeterminant use a broad 'using namespace std' to fix #442 in another
 way.
 git-svn-id: http://svn.osgeo.org/geos/trunk@3370 5242fede-
 7e19-0410-aef8-94bd7d2200fb
Ticket URL: <https://trac.osgeo.org/geos/ticket/444#comment:6>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
