[geos-devel] [GEOS] #719: Memory leak in GEOSIntersection_r
GEOS geos-trac at osgeo.org
Sat Apr 8 09:22:43 PDT 2017
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:  3.5.0
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"5feba83f888d840e3d7e5f6eaa90ab6e9c9f2efa/git" 5feba83/git]:
 #!CommitTicketReference repository="git"
 revision="5feba83f888d840e3d7e5f6eaa90ab6e9c9f2efa"
 Fix memory leak in extent-limited overlay operations
 The leak was introduced by recent enhancement of the class to
 support extent-limited operation. It was spotted by Mick Orridge
 who also provided the testcase, thanks !
 Fixes #719
 git-svn-id: http://svn.osgeo.org/geos/trunk@4048 5242fede-
 7e19-0410-aef8-94bd7d2200fb
Ticket URL: <https://trac.osgeo.org/geos/ticket/719#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
