[geos-devel] [GEOS] #768: Add STRtree nearestNeighbor function to CAPI
GEOS geos-trac at osgeo.org
Sat Apr 8 09:22:44 PDT 2017
 Reporter:  dbaston      |       Owner:  geos-devel@…
     Type:  enhancement  |      Status:  closed
 Priority:  major        |   Milestone:  3.7.0
Component:  Default      |     Version:  svn-trunk
 Severity:  Unassigned   |  Resolution:  fixed
 Keywords:               |
Changes (by Sandro Santilli <strk@…>):
 * status:  reopened => closed
 * resolution:   => fixed
Comment:
 In [changeset:"63d2554cf21c02362ab4c35e55ad03f90da003f2/git" 63d2554/git]:
 #!CommitTicketReference repository="git"
 revision="63d2554cf21c02362ab4c35e55ad03f90da003f2"
 Add GEOSSTRtree_nearest API
 Includes tests for the new API and pre-existing STRtree API
 Closes #768
 Patch by Daniel Baston <dbaston at gmail.com>
 via https://github.com/libgeos/libgeos/pull/61
 git-svn-id: http://svn.osgeo.org/geos/trunk@4184 5242fede-
 7e19-0410-aef8-94bd7d2200fb
Ticket URL: <https://trac.osgeo.org/geos/ticket/768#comment:7>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
