[geos-devel] [GEOS] #741: [PATCH] GEOSSimplify() returns empty polygon if inner ring dimension < simplify distance
GEOS geos-trac at osgeo.org
Sat Apr 8 09:22:46 PDT 2017
simplify distance
 Reporter:  rouault     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:  3.6.1
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"4f943df80cc80fbad6c990f19c8cc6cf12446e0d/git" 4f943df/git]:
 #!CommitTicketReference repository="git"
 revision="4f943df80cc80fbad6c990f19c8cc6cf12446e0d"
 Fix empty GEOSSimplify return on inner ring collapse
 Patch by Even Rouault
 See #741
 git-svn-id: http://svn.osgeo.org/geos/trunk@4311 5242fede-
 7e19-0410-aef8-94bd7d2200fb
Ticket URL: <https://trac.osgeo.org/geos/ticket/741#comment:10>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
