[geos-devel] [GEOS] #794: Rename geos_svn_revision.h to geos_revision.h, generate from git
GEOS geos-trac at osgeo.org
Sat Apr 8 09:22:48 PDT 2017
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:  GEOS Future
Component:  Default     |     Version:
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:  git         |
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"a6221c09870678284aec7fcb6f00d7b0ff5e9a3f/git" a6221c0/git]:
 #!CommitTicketReference repository="git"
 revision="a6221c09870678284aec7fcb6f00d7b0ff5e9a3f"
 Use git describe as revision code if SVN metadata is not available
 Fixes #794
 git-svn-id: http://svn.osgeo.org/geos/trunk@4393 5242fede-
 7e19-0410-aef8-94bd7d2200fb
Ticket URL: <https://trac.osgeo.org/geos/ticket/794#comment:12>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
