[geos-devel] [GEOS] #794: Rename geos_svn_revision.h to geos_revision.h, generate from git
GEOS geos-trac at osgeo.org
Sat Apr 8 09:34:08 PDT 2017
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  major       |   Milestone:  GEOS Future
Component:  Default     |     Version:
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:  git         |
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"f3440ab9ede150590c1c7cefabeb360f78990f10/git" f3440ab/git]:
 #!CommitTicketReference repository="git"
 revision="f3440ab9ede150590c1c7cefabeb360f78990f10"
 Rename svn_repo_revision.sh to repo_revision.sh
 .. even if it still only extracts the *SVN* revision (also from git log).
 See #794
 git-svn-id: http://svn.osgeo.org/geos/trunk@4389 5242fede-
 7e19-0410-aef8-94bd7d2200fb
Ticket URL: <https://trac.osgeo.org/geos/ticket/794#comment:14>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
