[geos-devel] [GEOS] #764: PreparedPoint::intersects gives incorrect results for MultiPoint
geos-trac at osgeo.org
Sat Apr 8 09:37:48 PDT 2017
Reporter: dbaston | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.6.1
Component: Default | Version: 3.4.2
Severity: Unassigned | Resolution: fixed
Keywords: |
Comment (by Sandro Santilli <strk@…>):
In [changeset:"d8e7ecbdc3fe2c1e2cd655bde3d66267e9c598c4/git"
d8e7ecbd/git]:
#!CommitTicketReference repository="git"
revision="d8e7ecbdc3fe2c1e2cd655bde3d66267e9c598c4"
Fix incorrect return from PreparedPoint::intersects
Includes unit test
Patch by Daniel Baston via
https://github.com/libgeos/libgeos/pull/60
See #764
Reverts r4081
git-svn-id: http://svn.osgeo.org/geos/trunk@4149 5242fede-
7e19-0410-aef8-94bd7d2200fb
Ticket URL: <https://trac.osgeo.org/geos/ticket/764#comment:10>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
