[geos-devel] [GEOS] #768: Add STRtree nearestNeighbor function to CAPI
geos-trac at osgeo.org
Sat Apr 8 09:37:48 PDT 2017
Reporter: dbaston | Owner: geos-devel@…
Type: enhancement | Status: closed
Priority: major | Milestone: 3.7.0
Component: Default | Version: svn-trunk
Severity: Unassigned | Resolution: fixed
Keywords: |
Comment (by Sandro Santilli <strk@…>):
In [changeset:"63d2554cf21c02362ab4c35e55ad03f90da003f2/git" 63d2554/git]:
#!CommitTicketReference repository="git"
revision="63d2554cf21c02362ab4c35e55ad03f90da003f2"
Add GEOSSTRtree_nearest API
Includes tests for the new API and pre-existing STRtree API
Closes #768
Patch by Daniel Baston <dbaston at gmail.com>
via https://github.com/libgeos/libgeos/pull/61
git-svn-id: http://svn.osgeo.org/geos/trunk@4184 5242fede-
7e19-0410-aef8-94bd7d2200fb
Ticket URL: <https://trac.osgeo.org/geos/ticket/768#comment:9>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
