[geos-devel] [GEOS] #832: LinearLocation::isValid and LinearLocation::normalize, faulty comparisons
geos-trac at osgeo.org
Sun Apr 23 00:04:09 PDT 2017
Reporter: nila | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Default | Version: svn-trunk
Severity: Unassigned | Resolution:
Keywords: |
Comment (by strk):
Can you try to add a test under tests/unit/linearref exposing a bad
consequence of that always-false comparison ? It would be great to
have the need-for-fix clearly shown and the later fix secured.
Ticket URL: <https://trac.osgeo.org/geos/ticket/832#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
