[geos-devel] [GEOS] #587: Memory leak in geos trunk
geos-trac at osgeo.org
Sun Aug 20 15:14:01 PDT 2017
Reporter: bradh | Owner: geos-devel@…
Type: defect | Status: new
Priority: minor | Milestone: 3.7.0
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by robe):
This ticket is so old I'm not even sure if it's an issue anymore and don't
know how to test it.
strk we keep on pushing this, you think we should just change to a won't
fix or verify it is even still an issue?
Ticket URL: <https://trac.osgeo.org/geos/ticket/587#comment:7>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
