[geos-devel] [GEOS] #638: Recommend a static_cast around assert strings
geos-trac at osgeo.org
Wed Feb 1 09:29:05 PST 2017
Reporter: goatbar | Owner: geos-devel@…
Type: defect | Status: closed
Priority: major | Milestone: 3.7.0
Component: Default | Version: 3.3.8
Severity: Unassigned | Resolution: fixed
Keywords: |
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"4331" 4331]:
#!CommitTicketReference repository="" revision="4331"
Add static_assert<bool> to strings inside of assert calls
Allows compiling with -Wpointer-bool-conversion.
Patch by Kurt Schwehr <schwehr at google.com>
Closes #638
Ticket URL: <https://trac.osgeo.org/geos/ticket/638#comment:15>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
