[geos-devel] [GEOS] #809: Test failure with MinimumClearanceLine with geos 3.6.1
GEOS geos-trac at osgeo.org
Wed Feb 1 13:31:53 PST 2017
 Reporter:  goatbar               |       Owner:  geos-devel@…
     Type:  defect                |      Status:  new
 Priority:  major                 |   Milestone:  3.6.1
Component:  Default               |     Version:  3.6.0
 Severity:  Unassigned            |  Resolution:
 Keywords:  MinimumClearanceLine  |
Comment (by goatbar):
 Still investigating.  Not surprising, I'm getting a failure on WKB
 reading.
 geos_unittest geos::io::WKBReader
   GEOS Test Suite Application
 geos::io::WKBReader: [1=X][2=X][3=X][4=X][5=X][6=X][7=X][8=F][9=X]
 ---> group: geos::io::WKBReader, test: test<1>
      problem: unexpected exception
      exception typeid: N4geos2io14ParseExceptionE
      message: "ParseException: Invalid HEX char"
 ---> group: geos::io::WKBReader, test: test<2>
 ---> group: geos::io::WKBReader, test: test<3>
 ---> group: geos::io::WKBReader, test: test<4>
 ---> group: geos::io::WKBReader, test: test<5>
 ---> group: geos::io::WKBReader, test: test<6>
 ---> group: geos::io::WKBReader, test: test<7>
 ---> group: geos::io::WKBReader, test: test<8>
      problem: assertion failed
      failed assertion: "Values are not equal: expected 'ParseException:
 Premature end of HEX string' actual 'ParseException: Invalid HEX char'"
 ---> group: geos::io::WKBReader, test: test<9>
 tests summary: exceptions:8 failures:1 ok:0
Ticket URL: <https://trac.osgeo.org/geos/ticket/809#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
