[geos-devel] [GEOS] #638: Recommend a static_cast around assert strings
GEOS geos-trac at osgeo.org
Tue Jan 31 11:28:25 PST 2017
 Reporter:  goatbar     |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.7.0
Component:  Default     |     Version:  3.3.8
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by goatbar):
 You can tell track to format a block of text.  e.g. I did `{{{#!patch`
 I can clone the repo and do a pull request.  I haven't used request-pull
 before.  Thanks for the pointer to https://git-scm.com/docs/git-request-
 pull
Ticket URL: <https://trac.osgeo.org/geos/ticket/638#comment:9>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
